Questo è un forum il cui scopo non è quello di creare lo scoop per vendere spazi pubblicitari, come fanno i tg. Chi fa tante ipotesi come se stesse su la vita in diretta rischia seriamente di fare la figura di Toninelli vicino ai piloni della A24 (non voglio metterla in politica ma rende bene l'idea). Ci sono indagini in corso che diranno quali sono le cause; l'elencazione morbosa di teorie più o meno plausibili la trovo veramente fastidiosa e tutta giocata sulla pelle dei morti, perché se fosse stato un cargo con il suo povero equipaggio nessuno se ne curerebbe minimamente.
Scusate lo sfogo
Bravo, grazie per aver compreso lo spirito di AC.
Interessane articolo del seattletimes.com
Ethiopian Airlines flight 302 crashed Sunday morning just six minutes after takeoff from Addis Ababa, killing all 157 passengers and crew. It was the second crash of a new Boeing 737 MAX 8 in just over four months, following the Lion Air crash.
It was the second crash of a new Boeing 737 MAX 8 in just over four months, following the crash of Lion Air Flight 610 in Indonesia on Oct. 29, which killed 189 passengers and crew.
Like the Lion Air plane, the Ethiopian MAX was a new aircraft. Ethiopian took delivery from Boeing on Nov. 15, 2018.
The crash will draw intense scrutiny for any link with the previous one because it is highly unusual to have two deadly crashes of such a new model.
The MAX, a new version of the 737, entered service in May 2017 and more than 350 are flying worldwide. Ethiopian has six more of the jets in its fleet and a further 23 on order.
RELATED FAA evaluates a potential design flaw on Boeing’s 737 MAX after Lion Air crash
John Cox, founder and Chief Executive of Safety Operating Systems, an aviation safety consultancy, said that though photos from the site indicate that the plane hit the earth very hard with massive destruction of the airframe, the flight data recorders should be retrieved quickly.
“They need to. Being a new airplane and with the tragedy in Indonesia a few months ago, they need to find out if there is a connection or not,” said Cox. “There’s a sense of urgency.”
Cox said it’s premature to think of grounding the 737 MAX fleet.
“We don’t know anything yet. We don’t have close to sufficient information to consider grounding the planes,” he said. “That would create economic pressure on a number of the airlines that’s unjustified at this point. We have to be patient and let the investigators do their job. They know the urgency.”
In a news conference, Ethiopian Airlines Chief Executive Tewolde Gebremariam, who had just visited the crash site, called it a “very sad and tragic day.”
He said the plane on recent flights had flown to Johannesburg and back, returning to Addis Ababa about 6 a.m. Sunday. He said neither the pilots on that flight nor ground-maintenance staff reported any issues.
“The routine maintenance check didn’t reveal any problem,” Gebremariam said. “It’s a brand-new airplane, well maintained.”
The jet had “flown for more than 1,200 hours,” he said. “It was a very clean airplane.”
After about three hours on the ground, the fatal flight to Nairobi was dispatched as normal and took off at 8:38 a.m. local time.
The pilot radioed air traffic control soon after, saying that “he had difficulty and wanted to return,” Gebremariam said. He was given permission to return to the airport, but the jet crashed at 8:44 a.m.
The pilot in command was a senior pilot with more than 8,000 flying hours experience, he said.
In a statement Sunday, Boeing said it is “deeply saddened” and extended sympathies to the families and loved ones of the passengers and crew.
“A Boeing technical team is prepared to provide technical assistance at the request and under the direction of the U.S. National Transportation Safety Board,” the statement said.
Any link to the Lion Air crash?
Preliminary investigation into the Lion Air crash established that a faulty sensor triggered a new flight control system on the MAX — called MCAS (Maneuvering Characteristics Augmentation System) — that repeatedly pushed the nose of the airplane down.
In response, Boeing sent out notification to all pilots worldwide warning them of this possibility, and provided instructions about how to handle the plane safely if it were to happen again.
Pilots struggled against Boeing’s 737 MAX control system on doomed Lion Air flight
Bole International Airport in Addis Ababa is at high altitude, 7,625 feet above sea level, and the terrain nearby is mountainous.
Flight tracking company Flightradar24, using information transmitted from the airplane, tracked Ethiopian Flight 302 for three minutes. However, coverage at low altitudes in the area is limited due to the terrain, and the data on the last minutes is not immediately available.
The Flightradar24 data that is available shows a fluctuation in altitude, with the jet climbing to 8,000 feet above sea level, then sinking to 7,700, then climbing again to 8,600. These figures have to be corrected for local air pressure so that data will need to be adjusted.
The Aviation Herald, a reputable website that tracks information on airline accidents, reported that the last transponder data available, corrected for atmospheric pressure, showed the plane about 24 miles east of Addis Ababa flying at 9,027 feet above sea level, or less than 1,000 feet above the terrain at that point, which was 8,130 feet above sea level.
It’s unclear if the unusual dip in altitude before the crash is the result of a relatively normal flight transition, such as if the pilot was manually flying the plane and momentarily got busy and was distracted, or evidence of some technical problem.
Certainly, because of the Lion Air crash, there will be an immediate focus on whether the MCAS system could have been activated on the Ethiopian flight.
The Lion Air flight data showed that airplane repeatedly losing and then regaining altitude for 12 minutes before the final dive into the sea, as the pilots struggled to pull the nose up each time MCAS pushed it down.
But MCAS cannot activate until the pilot has gained altitude and retracted the flaps that give the wings extra lift for takeoff. It’s not clear at this time what phase of flight the Ethiopian plane had reached and whether the flaps were retracted.
Gebremariam in Sunday’s news conference called Ethiopian, which has expanded rapidly in recent years, “one of the safest airlines in the world.”
The airline does have a very modern fleet. However, the airline suffered a previous 737 crash in 2010, when a flight from Lebanon to Addis Ababa crashed shortly after takeoff and killed all 90 people on board.
The investigation into that crash blamed the pilots for “mismanagement of the aircraft’s speed, altitude, headings and attitude through inconsistent flight control inputs resulting in loss of control.”
The airline said Sunday the passenger list from Flight 302 spanned more than 30 nationalities, including citizens of Kenya, Canada, Ethiopia, Italy, China, the U.S., Britain, France and Egypt.
Davvero potrebbe essere la poca conoscenza del MCAS ad aver fatto cadere l'aereo in una situazione di volo anomala.??
Bah, vedremo.
Anche Ethiopian e Cayman Airways oggi lasceranno a terra i loro 737 MAX (rispettivamente 4 e 2)
Grazie Enrico.bel pezzo. Sarebbe da far leggere a tutti i giornalisti italiani che saltano subito sulla sensazionalismo ogni volta che purtroppo viene giù un l’aereo.
Scusate lo sfogo
Va bene attenersi alle notizie ufficiali e non alle ipotesi, di certo non volevo mancare di rispetto a nessuno contrariamente a ciò che sostieni. Non c'è nemmeno da riflettere sul fatto di avere maggiore rilevanza mediatica: 3/4 persone contro 150, aereo vecchio contro aereo nuovo in forte diffusione e con dubbi già sorti per altro incidente, 8 italiani...
IGNORANZA E IDIOZIA ALLO STATO PURO.
http://www.giornalone.it/prima_pagina_libero/
Spero che la Boeing faccia cagare kerosene solido a Feltri e alla sua squadra di auguzzini.
Inutile sperare nell'ordine dei giornalisti in questo paese.
Speriamo intervenga anche Al Baker, il titolo diffama anche loro.
Io mi chiedo come sia possibile che l’ordine non intervenga in una situazione simile, considerata anche la reiterazione di comportamenti simili, così come mi chiedo come sia possibile che una feccia simile continui ad attrarre inserzionisti.
Purtroppo dubito che ci siano molti, in Boeing, che si filano quello che dicono gl'imbrattacarte italiani. Ma si spera sempre!
Su Canale 5 sta parlando un esperto sull’incidente ..
Inviato dal mio iPad utilizzando Tapatalk Pro
